Purge - Solution
If your purge command not working, Follow the below Steps.
- Ensure Purge.bat file is available in "load point directory:\Program Files\Creo 2.0\Parametric\bin".
- Ensure Purge.exe file is available in "load point directory:\Program Files\Creo 2.0\Common Files\M010\x86e_win64 or i486_nt\obj".
- Also Set config.pro option terminal_command to C:\Windows\system32\cmd.exe.
- Ensure under Environment variables, for user variables>>>new>>>PATH>>"load point directory:\Program Files\Creo 2.0\Parametric\bin".
- For System Variables>>>New>>Path>>"load point directory:\Program Files\Creo 2.0\Parametric\bin;%SystemRoot%\system32;".
Hope this will help your issue.
Manikandan P
