8-Gravel
June 15, 2022
Re: Creo 2.0 - Open a drawing from active part?
  • June 15, 2022
  • 2408 views
Hi
How I can  use the program with Creo in Italian Language?
    Best answer by remy
    After downloading the application and following the installation and running instructions, Creo is unable to run it in my envionment: our anti-virus system takes down the exe file.
    Consequently I'm sorry to inform that i'll be of no support on this topic.
    You need to use Creo in Italian Language.
    As there can be multiple possibilities to your question, there is a need to clarify where you are at right now.
    Do you mean that you installed Creo and the menus are in English and that you need them in Italian?
    Daniel828-GravelAuthor
    8-Gravel
    June 15, 2022
    I work in Italy the program and the menus are in the italian language.
    The program open_drawing_cr2.exe for open drw from part not work with italian language, but only with english.
    Dear @Daniel82
    Creo in Italian is installed correctly and you run a program called open_drawing_cr2.exe.
    This is the first i hear about this program.
    Can you tell me what it is ? and who supplied you with it?
