Renaming checked out parts in workspace
OK. I must be doing something wrong. I checked out some parts and assemblies into my workspace. What I want to do is rename a part (Ex: Hose_A_V001) as another name (Hose_A). Then I want to check Hose_A back in and have the original part (Hose_A_V001) go up one iteration with the new name (Hose_A).
When I do the rename (on server and in session), the original part doesn't get renamed in my workspace. Creo seems to do a Save As and it creates another part in my workspace with the new name. The assembly does show the new name. So, when I check everything in, both the original part AND the new part are checked in (I use the automatically un-checkout unmodified objects option). The original part (Hose_A_V001) still has it's current (.-1) iteration and the new part (Hose_A) is also present. So, now I have two versions of the same part, just different names. What I want is for it to go from (Hose_A_V001 version .-1) to (Hose_A version .-2).
I've been able to do a rename in Windchill but then I have to remove everything relating to the nenamed part (parts and assemblies) from my workspace, check everything back out and then it just shows the new name. Isn't this something that can be done on the fly??
