MY SYSTEM CONFIGURATION IS INTEL CORE2 DUO CPU P8400 @ 2.26GHz 2.27GHz
RAM 3.0 GB
WINDOW 8 PRO(32-BIT OPERATING SYSTEM)
CREO 5.0 IS VERY RUNNING SLOW ON MY SYSTEM.PLEASE TELL ME THE SOLUTION?????
THANK YOU
Please once have a look on software & hardware compatibility matrices for CREO, it will help you to choose system configuration....
upgrade your pc to 64 bit and add some memory may be 4 gb/b gb ram with 1/2 gb graphics card.
It looks like you use old age computer. The processor was launched in 2008. Its performance is poor when compared with current processors. See http://www.cpubenchmark.net/cpu.php?cpu=Intel+Core2+Duo+P8400+%40+2.26GHz
I think it does not make any sense to upgrade the computer ...
Martin Hanak
Here is the page Sandip is referring to.
try to upgrade to latest graphic drivers for windows 8.
is your hardware compatible with windows 8?
i think windows xp would be the solution to your problem.
well everything is ok to me.i'd suggest just make sure you got a good graphics card,my recommendation is nvidia gt 610,you won't face any problem.
Creo 5 ????
Creo Elements/Pro 5.0 (Pro/E Wildfire 5.0) probably.
Right
