Save a Copy
  • January 13, 2010
  • 6027 views
Hi When you go to Save A Copy,you get some File Directory shortcuts at the top,how do I go about to add my own Directories in there. Thanx Rene
    can you clarify or explain what is your problem ...
    If you want to make a new directory just right click inside the 'save a copy' window to make the new directory. If you want to choose a directory to save the file, choose the directory in the common folder to change the current directory in which proe will save your file. Does that answer your query?
    Do you mean create new FOLDER? When I right click in the window I get the option to create a new folder. If this does not work for you, go to the directory via 'my computer' and create the folder you want there. Then save as copy and select the folder from the window.
