Save a Copy
  • January 13, 2010
  • 6027 views
Hi When you go to Save A Copy,you get some File Directory shortcuts at the top,how do I go about to add my own Directories in there. Thanx Rene
    can you clarify or explain what is your problem ...
    If you want to make a new directory just right click inside the 'save a copy' window to make the new directory. If you want to choose a directory to save the file, choose the directory in the common folder to change the current directory in which proe will save your file. Does that answer your query?
    Please view attached picture,at the top next to the "look in" window,there is shortcuts to directories (small file icons). I want to add my own there. Right clicking anywhere in the big window does not work. Hope this makes my question more clear
