Save a Copy
  • January 13, 2010
  • 6027 views
Hi When you go to Save A Copy,you get some File Directory shortcuts at the top,how do I go about to add my own Directories in there. Thanx Rene
    can you clarify or explain what is your problem ...
    If you want to make a new directory just right click inside the 'save a copy' window to make the new directory. If you want to choose a directory to save the file, choose the directory in the common folder to change the current directory in which proe will save your file. Does that answer your query?
    Rene, First, using Pro/E browser, you could browse to that folder and add it to your favorites. Then when you do save-a-copy, you can click the favorites icon (I believe the 1st one from the right in your image)from the Save box and choose your folder. Another way is to set up a mapkey (an operation shortcut) that will go through the menu picking and browsing to that folder at the same time so you don't have to manually browse to it each time. That's what I would do.
