Save a Copy
  • January 13, 2010
  • 6027 views
Hi When you go to Save A Copy,you get some File Directory shortcuts at the top,how do I go about to add my own Directories in there. Thanx Rene
    can you clarify or explain what is your problem ...
    If you want to make a new directory just right click inside the 'save a copy' window to make the new directory. If you want to choose a directory to save the file, choose the directory in the common folder to change the current directory in which proe will save your file. Does that answer your query?
    I want to make a new directory in the "Save a Copy" window where it shows those small directory icons If I right click inside that window nothing comes up. Am I missing something?
