Show Erase - Creo 2 Config
ChrisCollinson
Hi All
Is anyone using the keep
OK, Sorted this issue out, Back in Wildfire 5/Creo Elements PTC decided to switch the names around so that Keep would now keep all checks in the check boxes and Remove would remove all the check boxes in teh Show Erase dialogue which is round the other way to what it used to be in Wildfire 3
There we go,
Thanks all
My users have the same complaint and it's confusing. I think it makes the most sense to select what you want to keep by default and not the other way around.
Maybe you need to create a mapkey that peforms the clicks for you giving you a one click process.
If anyone knows of a config option that will reverse the default behavior, please share.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
