Trouble with "Special" Characters
  • June 19, 2015
  • 10273 views
Hello Guys,
In some of ours workstations with PTC 3.0 (ALL with Windows 7 64 bit) it happens that, when a user save a file, some characters wrote in it  change when the same file is opened again or is opened by another user.
For example .. I write a "phi" character.. when i'm finished, I save the file and quit. When I re-open the same file instead "phi" I see another character (in this particular case I see " ' ", the one between quotes)
Why have I this strange behaviour? Also It seems that when the file is opened by Creo Viewer this problem doesn't appears....
There's someone that can help me?
Thanks for help,
Alessandro
Best answer by jskraba
How is your dxf_export.pro configuration file been set? When you exporting drawing from Creo to DXF or DWG you need to take care about mapping Creo fonts to AutoCAD fonts.
Creo font needs to be "compatible" with AutoCAD font where AutoCAD font name need to exist in AutoCAD configuration. Also mapped Creo fonts need to be installed in Creo installation directory.
In our dxf_export.pro configuration file we are mapping Creo font ISO.ttf to AutoCAD font isocp.shx so configuration file shows the following:
map_font iso isocp.shx
My suggestion would be to first try to change Text Style in 2D CAD to font which shows the correct symbols e.g. diameter symbol without changing anything else on the drawing. Open the drawing, click dimension to see text style being used, open Text Style window and select the dimension text style. Then change style to font which would best suit your company needs or standards and which shows diameter symbol correctly.
Then set mapping in dxf_export.pro to map Creo font being used on drawings and for dimensions to 2D CAD font which you previously tested. Repeat the export procedure and check the results.
As you mentioned 64-bit Windows 7 platform. We were experiencing similar problem with font characters not being translated correctly when exporting to PDF. We have found out that when Creo installation is placed on network drive (network installation), characters for some reason do not translate correctly. When the installation of Creo was moved to local disk, translation worked OK. According to our VAR it has something to do with Windows fonts not being read correctly from network install.
Alessandro,
please upload some pictures and Creo example file.
Martin Hanak
ablasi1-VisitorAuthor
Hello Martin,
I uploaded two files.
In the first one (file right_signed.png) I've marked the characters that is ok. When I Export this file in dwg format you will see that marked characters is different.
Is there some explanation?
Thanks for helping us.
Alessandro,
if I understand you well, then:
  1. you created a drawing in Creo (2.0 or 3.0 ?)
  2. when anybody opens this drawing in Creo, then PHI characters are OK
  3. you exported this drawing into DWG format
  4. when anybody opens in AutoCAD, then PHI characters are replaced by n letter
Can you comment my "procedure".
Martin Hanak
