Unite Technology
  • April 2, 2015
  • 5 replies
  • 2859 views
I have Creo 3 M010 loaded on my machine. I want to open up a Solidworks model into my session and I am getting the following error:
License for ATB SolidWorks (Collaboration_Ext_SolidWorks) is not available. ATB operations are going to be ignored.
This is what Unite Technology specified on their datasheet:
Open SolidWorks®, CATIA® and NXTM files directly in PTC Creo without the need for additional software Import SolidWorks, CATIA, NX, Solid Edge® and Autodesk® Inventor® files into PTC Creo without the need for additional software
Do I need a special license or module? or I should be able to do this out of the box.
I hope somebody alreade answered to your question, but if not...
The Unite technology that will allow you to open NX, Catia or SW files without conversion/translation is awailable starting in M030. I have noticed that you are testing M010.
cying12-AmethystAuthor
I have downloaded Creo 3 M030, it will open Solidworks 2014 but not 2015 yet.
In Solidworks 2015 can you save back to Solidworks 2014 ?
Carl
I don't see any options under 'save-as' in SW 2015 to specify the version number, so I would say no, at least in my version (SW 2015 Standard)
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
Hi there, we've seen this same message while trying to open a Solidworks file with Creo 3 M030 and M040 - though M020 doesn't show it.
I'm about to open a PTC Case to ask why open is not possible - this module should only be required for saving.
Ed
