User installed lmgrd.exe on system that already had lmadmin installed...clean up?
Server 2012R2 using lmadmin 11.14 installed in c:\Program Files. Edited the server.xml file to allow "ptcflush" (per doc CS47365). All good for 2 months.
Then I get a call from the customer saying that ptcflush is no longer working, it is returning the "you are not a license admin" error. Sure enough, some user with admin access installed lmgrd on another disk (E:) and this overwrote the server.xml file. I edited the server.xml file again and restarted the lmadmin_ptc service.
How do I remove lmgrd on drive E? I notice it does not have its own uninstaller. How do I clean that up?
I've only dealt with lmadmin so far, so forgive that I'm a bit fuzzy on how those two co-exist or not. I understand that lmgrd appears to install as a 32-bit app (based on where it ends up) and that it is a command line utility. That's about it at this point.
Thanks for any further info,
IG
