I am new to this company which uses PTC Wildfire 4.0 wanting to upgrade to Creo.
We have a license server and some workstations with Wildfire 4.0 installed on each workstation.
Any upgrade path or documentation that you can share with?
Thanks.
Eric
Are you using a PDM system with your Wildfire installation, as that will influence how you do your upgrade?
We use a single installation on a server, so everyone gets upgraded with a single installation.
A Creo upgrade is relatively easy, just install, copy over any customized files, like config.pro, hole files, etc, and go.
Eric,
Some of the articles about license and installation of Creo are available at:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS26798
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS170689
Please refer to Creo Parametric 3.0 Upgrade Resource Center https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS189753
