I'm back on to wildfire, I have a segmented part and am trying to show the diameter as a clipped dim but I can seem to get this to happen?
Is there a config setting to allow this? its been a while so can't remember
Hi Colin,
Which release of Wildfire are you using?
Amit
Sorry forgot to mention WF4 M220
Hi Colin,
To create a clipped dimension do the following:
Let me know if that doesn't work.
Amit
Amit's method is for a created dimension. For a shown dimension, use show as linear, and clip witness line (from the dimension properties dialog), IIRC.
