creo 6: How set openning Wrkpln->3D, not 2d?
ainniss
When my Creo opens ... the Default Wrkpln is, (changed-now> 2d).
How do I RESET it?   Thanks...
Mahesh_Sharma
22-Sapphire I
(To:ainniss)
HI,
Is your query is for Sketcher mode? If yes you can set config option sketcher_starts_in_2d as yes
dgschaefer
(To:ainniss)
Are you perhaps using Creo Elements Direct?  This area is focused on Creo Parametric and there isn't a default wrkpln in Creo Parametric. The Creo Elements Direct area is here:
PTC Creo Elements/Direct
LinkedIn
