default slant angle
  • November 10, 2022
  • 2 replies
  • 853 views
I am using Creo Parametric Release 4.0 and DatecodeM040
How to set the default slant angle for the text in drawing
Best answer by tbraxton
It is not possible currently in Creo.
  • Not part of Creo Parametric functionality
  • Workaround: create Mapkey to manually modify the Slant angle
See article:
https://www.ptc.com/en/support/article/CS59206
tbraxton
tbraxton22-Sapphire IIAnswer
See article:
tbraxton
One possible workaround is to create a font with the slant angle you want and use the font in drawing mode. I have not done this but maybe someone else will offer confirmation that this would work.
