default slant angle
HK_10169952
default slant angle
I am using Creo Parametric Release 4.0 and DatecodeM040
How to set the default slant angle for the text in drawing
tbraxton
(To:HK_10169952)
It is not possible currently in Creo.
  • Not part of Creo Parametric functionality
  • Workaround: create Mapkey to manually modify the Slant angle
See article:
https://www.ptc.com/en/support/article/CS59206
Involute Development, LLC
Consulting Engineers
tbraxton
(To:HK_10169952)
See article:
tbraxton
(To:HK_10169952)
One possible workaround is to create a font with the slant angle you want and use the font in drawing mode. I have not done this but maybe someone else will offer confirmation that this would work.
