file_open config not working
cdiaz-2
everytime i launch pro/e n hit file open it defaults to the "C:\Documents and Settings\cdiaz\My Documents\" directory but i would like it to default to my "C:\temp\proework\" directory. i tried setting this up in my config using the "file_open_default_folder" config setting but it still defaults to the "C:\Documents and Settings\cdiaz\My Documents\" directory. im running pro/e 4.0 with teamcenter. i looked in the config.sup for the current default address but i cant find it to change it. how do i permanently change my file open directory? any suggestions?
10 REPLIES 10
DavidButz
(To:cdiaz-2)
RMB on the Shortcut Icon on your Desktop which starts Pro/E, then Properties, then fill in your desired directory in the "Start in:" box.
cdiaz-2
(To:DavidButz)
the directory that was in the start in box was not the same directory it's defaulting to, but i tried it anyway and it doesn't make a difference... any other suggestions???
Kevin
(To:cdiaz-2)
Do you have the config option set to working directory?
MartinHanak
(To:Kevin)
Martin Hanák
cdiaz-2
(To:cdiaz-2)
"1.] Your config.pro file must contain the following option (check also PROE\text\config.sup): file_open_default_folder working_directory 2.] Your ProE shortcut must contain C:\temp\proework directory in Start In field. 3.] When you start ProE, you have to check (Tools>Options), whether your config.pro has been loaded. 4.] Also, try to run ProE without teamcenter. Martin" Martin, i dont have the config value "working_directory " for my config "file_open_default_folder" its just blank, theres no value in there.
Kevin
(To:cdiaz-2)
Does it give you a drop down list? There should be at least six options. If not what datecode are using? I'm using M110.
cdiaz-2
(To:Kevin)
i dont any of that, it's all just blank im on WF4.0 date code M120
Kevin
(To:cdiaz-2)
I'm not sure what would cause the drop down to be blank. I tried M120 and got the same options as before.
cdiaz-2
(To:Kevin)
my pro/e integration was just reinstalled due to some other error but apparently that fixed my blank value issue, i set it to working directory and set my start in folder correctly and now its up n running like it should thanks a million guys
