file_open config not working
  • April 7, 2010
  • 4851 views
everytime i launch pro/e n hit file open it defaults to the "C:\Documents and Settings\cdiaz\My Documents\" directory but i would like it to default to my "C:\temp\proework\" directory. i tried setting this up in my config using the "file_open_default_folder" config setting but it still defaults to the "C:\Documents and Settings\cdiaz\My Documents\" directory. im running pro/e 4.0 with teamcenter. i looked in the config.sup for the current default address but i cant find it to change it. how do i permanently change my file open directory? any suggestions?
RMB on the Shortcut Icon on your Desktop which starts Pro/E, then Properties, then fill in your desired directory in the "Start in:" box.
cdiaz-212-AmethystAuthor
the directory that was in the start in box was not the same directory it's defaulting to, but i tried it anyway and it doesn't make a difference... any other suggestions???
Do you have the config option set to working directory?
