home-use licenses
  • January 19, 2017
  • 2 replies
  • 53866 views
What is the format of files created with "Home-use license" ?? When file was created in trail version of Creo there is no possibility to open it in comersial version. Question is: Will it be possible with home-use license?? What in case when user did some work at home an took it to office?
Best answer by MartinHanak
when customer buys subscription license of Creo Parametric, PTC adds 2 Home-use licenses to every single commercial license as gift.
  • Users are allowed to install Home-use licenses on their personal home computers, only.
  • Home-use licenses must not be installed on company computers.
  • Home-use licenses enable users to do their production work at home.
  • Data created with Creo using Home-use licenses are readable with Creo using commercial license and vice versa.
MH
If I understand correctly, the hone-use license is a rebranded academic version and the files are not compatible with the commercial version.
If you need to do work at home, and have enough licenses, you can borrow a commercial version for a period of time realizing that your license pool at work has been reduced by 1.
Alternative is to permanently transfer a license from your work server pool to your home computer. We just did this for a manager so he can learn Creo 4.
At one point we were able to set up a VPN that allowed me to use a license from work on my home computer, pretty much as if I was actually at work. I haven't done it in a while, but it's likely still a possibility, if people have the appropriate IT support. That way you don't have to "borrow" a license, which makes it unavailable if you're not using it.
Gucio16-PearlAuthor
borrowing license or VPN connection sometimes is banned by company's policies. β€Œit was the reason for creating home-use license (I suppose).
But I want to be 100% sure that files will be readable in comersial version.
MH
this is very helpful,
but what then is the difference between a home use license and a commercial license?
what are the limitations?
thank you
KK
6-Contributor
October 19, 2020
I have a question. How would a user do to obtain this home license after installing Creo on a personal home computer.
We normally have a internal license server we connect to 7788@xxx  available through VPN. But home computers are not allowed through that VPN and the licensing server is not in a DMZ.
Is it possible to use simple Licence identification using the SON or SCN numbers ?
If so, how does PTC know that it is a Home license that is requested, and not one of the "real". multi-site
