3-Newcomer
June 13, 2012
how can I open a creo 1 .prt in wildfire 4 ?
  • June 13, 2012
  • 2 replies
  • 2296 views
How do I go about opening a creo 1 .prt in wildfire 4 and what config.pro options do I need to set ?
Is the GCRI solution favorable to loading many versions of Pro/E to stay compatible with many clients?
3D software has never been forwards compatible, meaning that you cannot open a newer version of a file in an older version of the software.
It does, however, work the other way around.
Sylvain's nailed it. There are actually some options for this... although it's a bit of jumping through hoops in my opinion. I'm not sure the status of GCRI with Creo but it's your best shot.
