modelcheck error can't be erased in a part
  • April 8, 2022
  • 2 replies
  • 2009 views
For design reasons, my R&D department made a chamfer on a part and then made a circle on the surface.
But... modelcheck, as defined, shows us an error: Entities without surfaces likely to be buried(1)
If I choose the feature in the dialog box and click "Ignore Feature", I get this message:
- Ignore parameter added to feature #4909.
I save, clean up my workspace, reopen the room, MC again but... the error recurs.
And if I choose to skip the feature again, I get these messages:
MC_BURIED_SUSPECT - parameter already exists.
I would like to understand where the MC_buried_suspect parameter is written, and why, my first action is not registered with my part.
Could you help me?
Regards
Best answer by Dom_BOUCHARDY
Yes, PTC support contact me, and we found the solution.
In my check files, i change the IGNORE_OPTION in interactiv mode from N to Y.
And it works.
Thanks for your support 🙂
22-Sapphire I
April 20, 2022
Hi @Dom_BOUCHARDY
Can you share the part file?
Thanks.
Hi Dom,
Will it works for you?
MC_BURIED_FEAT_IGNORE_MERGE_FEAT set to NO in config_init
Hi all,
@NSS: i don't have this option in our config_init.mc
Also, we want to test our 3D models so that they don't have burried functions.
@Mahesh_Sharma: Yes it is possible, but for privacy reasons I will open a PTC incident.
Regards
22-Sapphire I
May 9, 2022
Hi @Dom_BOUCHARDY
Did you manage to get solution from PTC TS?
Thanks.
