need a UDF or something to change drawings to dual dimensioning.
I am using Creo Parametric Release 9.0 and Datecode9.0.4.0
I have 3 groups in our company that use the same config.sup and config.pro.
All use the same drawing formats. One group want to use dual dimensioning. I am not willing to give them different drawings with different .dtl files.
Is there a way to create UDF or set a local config option that will allow them to use dual dimensioning without going thru all of the selections to set up dual dimensioning? i have the drawing .dtl file set up so that when they change to dual dimensioning, all other settings are ready to go.
Just looking to shorten the 9-10 clicks per drawing to change to dual dimensioning.
Here are the errors that I faced
no errors
