notation options for ENV=PTC_D_LICENSE_FILE
  • July 11, 2018
  • 2 replies
  • 23562 views
Hello All,
Is anybody able to explain to me how it is possible that adding:  Serialnumber@Flexnetversion as a ENV=PTC_D_LICENSE_FILE in the *.psf file , creo connects to the license server?
e.g.:"ENV=PTC_D_LICENSE_FILE=7788@xx.x.xx.xxx;7788@xxxxxxxxx;2017260@11.14.0.1
xx.x.xx.xxx = IP4 adres server
xxxxxxxxx = name server
2017260@11.14.0.1 = Serialnumber of flexnet   @   Version of flexnet
adding this: 2017260@11.14.0.1 to the ENV line resulted in being able to connect to the license server, without this text, starting Creo resulted in a (-96) Failed to connect to server...
BR
Ferry
PTC_D_LICENSE_FILE variable is used to define path to license manager.
Path format ... TCP_port_number@server_ID
TCP_port_number
  • default number is 7788
  • IT admin can change default number
  • I think that in your case default number was changed to 2017260 - therefore 7788 does not work
server_ID
  • ID can be server name -OR- server IPv4 address
Thank you Martin for your reply.
I understand your explanation about the tcp port and Server ID.
We have checked the details of the  FLEXnet web admin at customer  and 2017260 seems to be the serial number and 11.14.0.0 can maby be an IP4 adress but is also the current version of the software.
BR
Ferry
2017260 is too high for a TCP port. 11.14.0.0 would be a very strange IP. Is it an public IP.
Which server lists Creo? Open Creo got to File > Help > System Information -> Servername:...
how about ptcstatus.bat?
br Bernhard
FYI, 2017260 is the build code for Creo Parametric 4.0 M030.  I don't think it has anything to do with Flexnet.
Hello TomU,
I am not familiar with a Creo date code in that form. Is there a method of finding such a number within my own Creo Parametric Session?
The code 2017260 is mentioned in the Flexnet Publisher Webinterface under System Information and is called Volume Serial Number.
BR Ferry
Previous information ...
In the picture there is no code 2017260. The picture does not contain any usefull information. You removed server name, server IP address, FLEXnet port number.
