problem: 64bit CoCreate PE3 will not start
I have deleated and reinstalled PE3 several times.--The program starts ,flashes a work screen but then quits.
It may need login info but there are no screens to do this, where is this info kept?
That is the wrong one.
The users application data folder is normally hidden, and you first need to change your folder properties to see hidden files and folder.
In my case the path to the folder to be deleted is:
D:\Users\<username>\AppData\Roaming\CoCreate\CoCreate Modeling Personal Edition 3.0\30.0
The personality folder under the program installation path must not be deleted (needs to be re installed)
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
