problem regarding dimensions witness lines in Creo drawing
I am using Creo Parametric Release 4.0 and DatecodeM150
I am facing some problem regarding dimensions witness lines in Creo drawing. Every time I regenerate, or check-in check-out part, dimension witness line gets disturbed (elongated in/out of view). Problem seen specifically for Parametric dimensions which are converted to ordinate dimension.
