running Solidworks and Creo on the same laptop
  • August 22, 2018
  • 5748 views
Anyone is having issue running Solidworks 2017 and Creo 5.01 on the same laptop?
    Best answer by Dale_Rosema
    Don't forget to mark your answer as correct for those who may search and find this thread.
    Are you possibly running Windchill 11.1?  There is a known issue where the embedded web browser doesn't work correctly when Creo 5 and the workgroup manager are both installed.  See CS289364.
    I'm also having a different issue with Windchill 11.0 M030 (CPS11) where the workgroup manager does not start correctly with Solidworks 2018 (SP4).  This issue has not been resolved yet...
    Willy_4081-VisitorAuthor
    Thank you for the update,  I found the issue to becoming from windows update version 1803.  It's messing up my license with Flexnet
    Dale_Rosema
