slow performance using BOM [repeat region] on creo 4.0
I am using Creo Parametric - Release 4.0 (connected) Release 4.0 and DatecodeM140
10 sheet drawing with BOM [repeat region of 89 parts] is a very slow process, [1.5 hour] to open all sheets and then create a PDF. when i removed the BOM and saved it, got out of session, recalled it back up [wo BOM] and it takes 1.5 minutes to open all sheets and create a PDF. With some of the obvious config.pro settings to improve time are already set ; are there any other config.settings that are for the repeat regions
Here are the errors that I faced
none ; just time consuming
