vb api centering quote text
Hi, can i center the quote text in drawing with vbapi in Creo 4?
At the moment i can select the quotes but i cant find any method for centering the text.
If i do it manually, i select the quotes then click on the ribbon on Visualization and under configuration i change it first in center on guide and after on linear.
Can i do this with the api?
