The PTC Community will be on read only status starting March 23rd in preparation for moving our platform to a new provider. Read more here
You can share a procedure in Vuforia Editor so that, for example, two authors can modify a procedure. If these two authors start working on a procedure at the same time, they are not informed that another author is also working on the procedure. At the moment I notice that changes made by the other author are overwritten. Is simultaneous collaboration on procedures even intended and supported as a functionality?
Thank you for your help.
@pjahn --This scenario is mentioned in the product documentation, and includes a recommendation on how to avoid this issue:
"Currently, it is possible for multiple users to edit and view a procedure at the same time in Vuforia Editor. This will result in changes being overwritten, and we highly recommend that, if possible, only one user at a time edit a procedure to avoid losing work."
Best regards,
Amanda
Same question - "How multiple team members can work on same experience development using vuforia studio?": https://community.ptc.com/t5/Vuforia-Studio/How-multiple-team-members-can-work-on-same-experience/td-p/657622
I was asking about collaboration in Vuforia Editor. The article you posted is about Vuforia Studio.
Best regards,
Amanda
