Larger video area
dmforbes
Larger video area
In Expert Capture, if I do not add any text to a step, is it possible to make the video area larger, to use all of the screen space?
The initial image/video size does not change depending on if there is text or not. However, you can 'Open' the video to see it in full screen mode.
dmforbes
(To:tmccombie)
thank you for the response.
the bigger idea would be that i could have a 1 step experience, and when that step is activated, the video automatically starts, and is full screen, so I can embed this at a work station, and built into an MES or work instruction
