The PTC Community will be on read only status starting March 23rd in preparation for moving our platform to a new provider. Read more here
In Expert Capture, if I do not add any text to a step, is it possible to make the video area larger, to use all of the screen space?
The initial image/video size does not change depending on if there is text or not. However, you can 'Open' the video to see it in full screen mode.
thank you for the response.
the bigger idea would be that i could have a 1 step experience, and when that step is activated, the video automatically starts, and is full screen, so I can embed this at a work station, and built into an MES or work instruction
