Message "There a no steps in this procedure"
  • November 18, 2020
  • 4953 views
I captured a procedure with HL2 (latest os build). After some work in the editor I published the procedure which consists of 6 steps. Also in the preview there a 6 steps shown. Desktop playback also shows 6 steps. After opening the procedure in Vuforia View (iOS 14.2, latest app version) the following message is shown: "There a no steps in this procedure".
I did not find out why this happens. Any hint is appreciated.
Hmm. That's very strange. Do you get the same error if you try to view the procedure on a different device? I'd be interested in seeing the View logs - can you share those for review?
pjahn16-PearlAuthor
Yes, I have tried this on different iOS devices with the latest version of Vuforia View an iOS/iPadOS available. It does not make a difference. Vuforia View says that there are no steps in the procedure. Desktop view works and shows the steps.
I've attached a logfile from Vuforia View taken from my iPhone 11 Pro.
Thanks for the additional information. I'm not seeing anything glaringly wrong in the logs. I've sent this over to R&D for an extra pair of eyes to take a look. Is it only happening for this specific procedure?
