Pass/Fail States Column Renamed in Step Check Settings
The column previously named PASS/FAIL STATES in the Step Check Settings table has been renamed to PASS/FAIL CAPTURES. Therefore, instead of displaying the number of training images, the number of captures will be displayed. A capture is comprised of one training of a pass or fail state. For example, each time a new dome of hexagons is shown during Guided training, a new capture starts. A new capture also begins for every execution of a step when Continue Training is enabled.
Note: Similarly, the number under the Pass and Fail thumbnails will also now display the capture count.
Vuforia Vantage
iOS
iOS/iPadOS 17 is now supported.
iOS/iPadOS 15 is no longer supported.
If tracking becomes unreliable (not lost) during Step Check training, training is paused, the dome stops appearing, and a Tracking is unreliable message appears.
For steps with Step Check enabled, the augmentation that helps guide users to the correct angle is now always displayed when the point of interest is out of camera angle.
Note: The augmentation is not displayed when Step Check is in Setup mode.
Android
Android 14 is now supported.
If tracking becomes unreliable (not lost) during Step Check training, training is paused, the dome tiles stop appearing, and a Tracking is unreliable message appears.
Vuforia Insights
Updates to Viewer Insights Table Column Order
In the Viewer Insights table, the columns displayed in the results have been reordered as follows:
Date/Time
Username (appears only if the Remove User Information and Dates from Viewer Insights is turned off in Product Settings)
Email (appears only if the Remove User Information and Dates from Viewer Insights is turned off in Product Settings)
Role (appears only if the Remove User Information and Dates from Viewer Insights is turned off in Product Settings)
Procedure
All remaining columns are unchanged
Note: The updates above will also be reflected in exported reports.
New Filters for Viewer Insights Table
On the Viewer Insights page, new filters have been added for Username and Email.
Note: Filters will only appear if Remove User Information and Dates from Viewer Insights is turned off in Product Settings.
Updates to Default Columns in Audit History Table
In the Audit History table, the default set of columns has been updated to the following:
Date/Time
Username
Email
Role
Event Type
Procedure
Ability to Select Additional Columns to Display in Audit History Table
In the Audit History table, users can now select additional columns to display in the results table.
Note: Adding an additional column will also expose an additional filter for the associated column.
New Audit History Events
In the Audit History table, the following new audit history events are now recorded and displayed:
When Administrators makes changes to values on the Product Settings page
When Administrators select Enable Update on the Product Updates page
Note:
The events will be displayed in the user interface, but will not be included in the Audit Trail report. A message has been added to the cover page that indicates that these events are not included in the PDF report.
The new events started being recorded at the time of the 3.10.0 release; however, they will only be exposed in the Audit History table after the 3.12.0 release.
