Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
What's New in Vuforia Expert Capture and Vuforia Instruct 3.3.0
Vuforia Editor
Updates and Improvements to TASKS Page
The following updates and improvements have been made to the TASKS page:
Approved, Cancelled, Rejected, and Pending candidates are now displayed
The following filters are now available for the TASKS table:
Filter By Status
Filter By Role
The USERNAME column now displays the name of the user that created the approval workflow with Submitter next to their name
The TIME STAMP column displays:
The time and date that the approval workflow was created if the row is for a Submitter
The time and date that an assigned approver completed their task
The TASKS table is now sorted by TIME STAMP
Updates and Improvements to Step Check (Beta)
The following updates and improvements have been made to the Step Check functionality:
Blurry images captured during training are now automatically discarded before uploading to Vuforia Editor
The Step Check Settings section has been moved from the PUBLISH tab to the STEP CHECK tab
Improved user experience for START TRAINING action
Vuforia Vantage
Improved Voice Commands on RealWear Devices
Improvements to voice commands now allows you to easily open favorited and downloaded procedures without having to say the full procedure name
Vuforia Insights
Date Filter on AUDIT HISTORY Table Uses UTC
The date filter on the AUDIT HISTORY table now uses UTC time.
For example, in past releases, if a user is in Central Time zone and logs into Insights at 11:00 am local time, sets a date range of December 4-11, and then clicks Download Report, the cover sheet will show a date range of Dec 4, 2022, 6:00 AM UTC - Dec 12, 2022, 5:59 AM UTC. This was because local time was being used as input and was adjusted based on time zone to reflect the equivalent time in UTC. Now, with this update, a date range of Dec 4, 2022, 12:00 AM UTC - Dec 11, 2022, 11:59 PM UTC will be displayed
Settings
Disable/Enable Step Check Setting Now Visible Only to Vuforia Instruct Users
The Disable/Enable Step Check setting is only visible to customers with a Vuforia Instruct license, and will no longer be visible to customers with only a Vuforia Expert Capture license
