7-Bedrock
June 16, 2022
Alternate for if-else statement
  • June 16, 2022
  • 3089 views
In an experience I've 20 3D labels visibility to control on each step(total steps 7).
$scope.checkStep = function(){
        console.log($scope.app);
           if($scope.view.wdg["model-1"].currentStep == 1){
              $scope.app.view.Home.wdg["3DImage-1"].visible = true;
              $scope.app.view.Home.wdg["3DImage-2"].visible = true;
              $scope.app.view.Home.wdg["3DLabel-1"].visible = true;
              $scope.app.view.Home.wdg["3DLabel-2"].visible = false;
              $scope.app.view.Home.wdg["3DLabel-3"].visible = false;
              $scope.app.view.Home.wdg["3DLabel-4"].visible = false;
              $scope.app.view.Home.wdg["3DLabel-5"].visible = false;
              $scope.app.view.Home.wdg["3DLabel-6"].visible = false;
          else {
              if ($scope.view.wdg["model-1"].currentStep == 2){
                  $scope.app.view.Home.wdg["3DImage-1"].visible = false;
                  $scope.app.view.Home.wdg["3DImage-2"].visible = false;
                  $scope.app.view.Home.wdg["3DLabel-1"].visible = false;
                  $scope.app.view.Home.wdg["3DLabel-2"].visible = true;
                  $scope.app.view.Home.wdg["3DLabel-4"].visible = true;
              else {
                  if ($scope.view.wdg["model-1"].currentStep == 3){
                      $scope.app.view.Home.wdg["3DLabel-3"].visible = true;
                  else {
                      if ($scope.view.wdg["model-1"].currentStep == 4){
                        if ($scope.app.params.step == 4){
              $scope.app.params.step = 1;
          else {
              $scope.app.params.step = $scope.app.params.step + 1;
Like the above code I've to do this for 20 3DLabels. Anyone please suggest any other way to achieve this, Rather than using IF-Else statements for all the steps.
Best answer by Mohit_Kabra27
Hi @Karthik ,
So basically what i mean is, you can define a function like below:
$scope.hide = function(){
$scope.view.wdg['3DLabel-1']['visible'] = false;
$scope.view.wdg['3DLabel-2']['visible'] = false;
$scope.view.wdg['3DLabel-3']['visible'] = false;
$scope.view.wdg['3DLabel-4']['visible'] = false;
$scope.playStep = function () {
let stepnr = $scope.view.wdg['model-1']['currentStep']
switch (stepnr) {
case 1:
$scope.hide();
$scope.view.wdg['3DLabel-2'].visible=true;
$scope.view.wdg['3DLabel-3'].visible=true;
break;
case 2:
$scope.hide();
$scope.view.wdg['3DLabel-4'].visible=true;
break;
Let me know if this works for you
BR,
Mohit
Hi @Karthik ,
You can try using switch-case, you can refer this link for more details : https://www.w3schools.com/js/js_switch.asp
BR,
Mohit
Karthik7-BedrockAuthor
7-Bedrock
June 17, 2022
Hi Mohit,
For that too I need to change visibility properties to true or false for all 20 labels in each case right?
$scope.setWidgetProp('model-1', 'currentStep', 'stepnr');
$scope.playStep = function (stepnr) {
switch (stepnr) {
case 1:
$scope.view.wdg['3DLabel-1'].visible=false;
break;
case 2:
$scope.view.wdg['3DLabel-2'].visible=false;
$scope.view.wdg['3DLabel-3'].visible=false;
break;
case 3:
$scope.view.wdg['3DLabel-4'].visible=false;
$scope.view.wdg['3DLabel-5'].visible=true;
Regards
Karthik
Hello @Karthik ,
if you want  to set  many widgets e.g. to visible  and let say they have some common string in the name you can use a construct like this:
$scope.setWdgsVisibility=function(str,value){
 var wdgs=$scope.app.view.Home.wdg;
 for(wdg in wdgs)
 if( wdg.indexOf(str) !=-1) {
 $scope.setWidgetProp(wdg,'visible',value);
 $scope.$applyAsync();
and let say you need this function to call for all widgets with name containing "3DLabel" you can call
$scope.setWdgsVisibility("3DLabel",true);
// or to false -> not visible
$scope.setWdgsVisibility("3DLabel",false);
to set all 3DLabel to visible. You can further then enhance it  for example if you want to have all 3DLabel widget with names range e.g.  "3DLabel-4 ....  3DLabel-15 you can use some construct like this:
$scope.setWdgsVisibility=function(str,fromNr, toNr,value){
for (let wdgNr=fromNr; wdgNr <= toNr; wdgNr++) {
 for(wdg in wdgs)
 if( wdg.indexOf(str+wdgNr) !=-1) {
 }//for wdgsNr
// and later call
$scope.setWdgsVisibility("3DLabel-",1, 4,false);
$scope.setWdgsVisibility("3DLabel-",5, 15,true);
$scope.setWdgsVisibility("3DLabel-",16, 20,false);
So this will set all 3DLabel-1 ..4 and 3DLabel-16 ..20 to not visible and all 3DLabel-5 ..15 to visible
