BluePump does not present on Vuforia View after updating Vuforia Studio to 8.4.5.4404
anishi
I'm using BluePump demo data from developer portal site as following.
https://developer.thingworx.com/ja/resources/guides/blue-pump-ar-tutorial/add-3d-model
When I was using Vuforia Studio old version, BluePump was displayed with the property, "sequence list is teardown - demo" and checked with Apply sequence at design time.
But after updating vuforia studio 8.4.4 or later, BluePump is not displayed anymore when the sequence is set to teardown-demo.
When I choose off the sequence like "--Choose a resource--", it is displayed again.
Could you check teardown sequence and bluepump data, please?
anishi
(To:anishi)
Hello again,
My colleague found CAD sequence data is wrong because bluepump is not visible in initial state.
He modified it and confirmed it shows properly.
Please use attached file, blue_pump2.zip
anishi
(To:anishi)
Hello again,
At the current time -  it seem that the link in your post was changed and is not valid any more. Therefore I want to add the correct link.
Guide "Develop an AR Experience Demo" - this is the guide which use the mention model
the Link to download the model
I did not checked it further but I believe that the  model in thenew link is already correct
