Hello Asiya,
Augmented Reality published from Creo Parametric or from Vuforia Studio are not published on the same Vuforia Experience Service.
Creo Parametric is using a custome and only one Experience Service hosted at PTC with some limitations.
If you want to have the 3D Model in Creo Parametric, you can import it in Vuforia Studio.
For that, please follow these steps :
- In Creo Parametric, export 3D model in pvz file format by using the File > Save As > *.pvz menu
- In Vuforia Studio, in the Project, in the left PROJECT panel, under RESOURCES, click the + button
- In the Add Resources dialogbox, click the Select Files button
- Select the pvz file exported previously at the step 1
- In the View, in 3D, in WIDGETS panel, under AUGMENTATIONS, drag and drop Model into 3D CANVAS
- In the MODEL- DETAILS panel, under PROPERTIES, in the Resource list, select the Resource uploaded at the step 4
Best regards,
Samuel
