External data detection
I am currently trying to add a function to my AR experience, which relates to a tutorial of how to fix a fault.
I have successfully used a button to trigger a function, which will detect the external data whether stays within the acceptable range or not. If it's not, then some warning messages will be generated.
Could I remove the button and the system will detect the external data in real-time?
For example, if the data does not fall within that range, those warning messages will be shown automatically.
