FPS drop during computing
  • July 6, 2022
  • 2978 views
Hi, I want to share a possible problem in my AR experiences. When there is a heavy data iteration (eg for loop through JSON metadata) while running the experience, the FPS goes very low.
How can I solve it?
Hi @GianVal ,
the question is what kind of iteration is it - I think such behavior could be  normal if you do any iteration steps in nearly infinity loop.
So what you can do if the loop is doing some calculation which are not directly affecting widgets properties and display then you can try to call the calculation to second thread - e.g.
https://medium.com/jspoint/achieving-parallelism-in-javascript-using-web-workers-8f921f2d26db
https://www.w3schools.com/html/html5_webworkers.asp
https://web.dev/workers-basics/#toc-inlineworkers
Another points is to call in each iteration the call
$scope.$applyAsync();
or to call each iteration as function with $timeout service with / or without delay
So for example you can try something like this:
let myDelayPerItterationCall = 100; //so 100 millisecond per call delay
for(let i=0; i< verylargeNumber; i++)
$timeout(()=>{
 myFunction1();
 myFunctionN();
 }, myDelayPerItterationCall *i) //end timeout call
} //end for loope
GianVal15-MoonstoneAuthor
I apply a "showobject" method to ALL the parts of my structure. To do this I perform a for loop on the entire model metadata structure.
I know that is a huge computational load, but I will investigate on webworkers solution.
I tried with $scope.$applyAsync() and timeout method but they don't work.
Thank you for the reply. The point is that I call the following method for all components (about 5000):
function show3DObject(name) {
 tml3dRenderer.setProperties(name, { hidden: false });
The for loop where the method is called ends up pretty quickly (in fact I just placed a spinner on hold and it disappears in a few frames).
In my opinion, I need to place a spinner awaiting the resolution of the tml3drenderer promise, but obviously, I don't have access to that built-in method.
