Is there a possibility to get the orientation of the mobile device? I would like to adapt the size of the pictures and buttons dependign on the orientation of the mobile. Is there any event sended if the orientation ist changed?
Thanks for help!
Thanks for your help, again.
Now I have the problem that screenorientation is always landscape-primary. I tested it in chrome with the preview function and changed the orientation by clicking the change orientation button at the top of the preview site. Every time I change the orientation a changeorientation event is released, but it always says landscape. Is this function not possible at the preview?
Greetings
I have found various ways to do that :
I have tried the second one with the orientation object.
Please read this documentation :
https://developer.mozilla.org/en-US/docs/Web/API/Screen/orientation
As we can read, it is not supported in Safari web browser for iOS.
In a new Project, in 2D canevas, I have added one Button and one Label named label-Result.
In home.js, I have created this function very similar to the one provided in documentation above.
$scope.screenOrientation = function()
var orientation = screen.msOrientation || (screen.orientation || screen.mozOrientation || {}).type;
if (orientation === "landscape-primary" || orientation === "landscape-secondary")
$scope.setWidgetProp("label-Result", "text", "landscape");
console.log("landscape");
else if (orientation === "portrait-primary" || orientation === "portrait-secondary")
$scope.setWidgetProp("label-Result", "text", "portrait");
console.log("portrait");
else if (orientation === undefined)
$scope.setWidgetProp("label-Result", "text", "The orientation API isn't supported in this browser");
console.log("The orientation API isn't supported in this browser :(");
Tests done :
So, to go deeper, we can see this thread in stackoverflow.com :
Best regards,
Samuel
Thanks for help. Do you know, how to catch the event orientationchange, too?
I have improved my demo.
Now, it works fine in Chrome and iOS about portait and landscape.
About the event orientationChange, we can found details here :
https://developer.mozilla.org/en-US/docs/Web/Events/orientationchange
http://www.williammalone.com/articles/html5-javascript-ios-orientation/
I have checked various syntaxes but when testing in iPad, all of them didn't work...
Code updated :
// Chrome
$scope.setWidgetProp("label-angle", "text", screen.orientation.angle);
console.log("the orientation of the device is now " + screen.orientation.angle);
// Chrome
// iOS
$scope.setWidgetProp("label-angle", "text", window.orientation);
console.log("the orientation of the device is now " + window.orientation);
if (Math.abs(window.orientation) === 90)
// Landscape
else
// Portrait
// Note that "orientationchange" and screen.orientation are unpre fixed in the following
// code although this API is still vendor-prefixed browsers implementing it.
window.addEventListener('orientationchange', $scope.screenOrientation);
window.onorientationchange = $scope.screenOrientation;
window.addEventListener('onorientationchange', $scope.screenOrientation);
// Listen for resize changes
window.addEventListener("resize", function() {
$scope.screenOrientation();
}, false);
To be honest, I am sure to understand why this event doesn't work in iOS.
It seems a limitation in Vuforia View.
Best regards,
Samuel
Greetings
I have the same problem in Preview in Chrome.
To avoid that, i have followed these steps :
Best regards,
Samuel
I have found why it is not working in Android.
I have disabled Rotation auto in Settings.
By enabling it, it works as like a charm.
Best regards,
Samuel
