Google maps, or maps integration in Vuforia studio
  • August 2, 2019
  • 1470 views
Hi all,
Do anyone know if it is possible to integrate google maps, or any map service, into Vuforia Studio? In the case, how would one proceed?
Thanks, Paal.
Best answer by RolandRaytchev
Hi @pathorse ,
so far I know, there is no possible direct google play map integration. The question is - what your particular application case is and why you need to call it directly in Vuforia view
The google map could  be used in thingworx mashup. So you can use a hyperlink widget to call a link to a mashup where your already  inserted the Google map Thingworx  widget.
But you could use any click events on any Vuforia studio widgets and call an external link via JavaScript
Hi @pathorse ,
