Highlight outline of model item
  • August 8, 2018
  • 935 views
Hi all,
I am trying to show which parts of my model are interactive, so I was wondering if it was possible to add a highlight to the perimeter of a model item? Or is there a better way to demonstrate model interactivity to the user?
This is a really needed feature in Studio, the ability to change the shader for models and modelItems to help show stuff like this. Currently your only options are to change the color and opacity. So you could make everything that is interactive red buy assigning them modelItems (which you likely already have) and then changing the color to red. You could also make the main model opacity low like 0.5 and then all your modelItems opacity 1. This will leave everything non-interactive ghosted.
