Hi All,
I encountered a problem with the latest version of the View app on HoloLens after the update to 8.4.1 came late last week.
I had an experience created that used a textured model created from an FBX file. The experience was working fine on the HoloLens using View 8.4.0, but after the update to 8.4.1, the view app crashes out when loading up the model
. I had to create a new version of the experience that doesn't have any textures and that loads up fine.
This happened on 3 different HoloLens's all running the latest version of Windows and 2 of them have been recently reset with nothing on them apart from the View app.
It's not a memory issue as the performance graph from the device portal shows. You can see the the loading, and then the plateau when the app crashes and the drop when it exits out of view which is still way below the memory limit:
It's not a global problem, as I have other experiences with textures that load up OK. Attached are the QR codes for the two versions of the experience - with and without textures. Unfortunately, I can't go back to the older version of the View app to try again.
@tmccombie or @RolandRaytchev is this something that R&D can look at as I believe it's a bug that has come in to 8.4.1.
Many thanks,
Allan
Well 8.4.3 was released and I'm very pleased to see that the problem has now been fixed.
8.4.0 - My model with textures worked ![]()
8.4.1 - My model with textures crashed View ![]()
8.4.2 - Textures support for HoloLens removed completely ![]()
8.4.3 - Textures back and my model with textures works ![]()
Thanks @RolandRaytchev for your help with this.
Hi @AllanThompson ,
thanks for reporting this issue! I did fast check and did not find related issue in the PTC database. (key words: HoloLens Texture ) - so there are some issues but not related to a different behavior between 8.4.0 and 8.4.1
I will test today or tomorrow projects with texture coming form Creo Parametric so will try to reproduce the issue. In case that issue is not reproducible I will need your assistance to provide some model or project to reproduce the issue... but as mention I need to test first if this is a general issue with textures in the new release
so tested the 2 QR codes GT_HoloLens_shareQR.png - here could reproduce the chrash of the vuforia view on the Hololens
the other QR code GT_HoloLens_No_Textures_shareQR - works fine - but I see that this model seem to be complex.
I have Vuforia view 8.4.1 build 197. What was the datecode where are able to load the project QR code GT_HoloLens_No_Textures_shareQR ?
Seems to be there are peak of the memory and network usage but I was observed also such behavior when I am testing features which are working fine.
Could you reproduce the issue also with models having texture with less complexity?
Hi Roland,
Unfortunately, I can't tell you the exact build version of View that I was running that worked with the textured experience, but it's the version that was available on Wednesday last week from the Windows Store as I had to install it on two of the three HoloLenses that I was using for the first time on Wednesday. On Friday morning my time, the new version was available, and I updated the third HoloLens with this version and started having the problem. Then on Saturday the other two must have updated automatically (I don't own them or have them now) as they also started having the problem.
I've tested some other models that use textures and these are working fine.
While I agree that it's a relatively complex model for the HoloLens, the issue is that the experience was working fine in the 8.4.0 version of View and then after updating to 8.4.1 - something that unfortunately you can't control on a Developer edition of the HoloLens, the same experience crashes out every time when loading. And looking at the memory trace on mine, it crashes out before it even maxes out the RAM usage. Maybe it tries to load the textures and it fails as there's not enough available RAM?
Allan
Hi Allan,
I reported today the issue to internal development group and just received the message:
"I was able to replicate the error in the released build. The issue has already been identified and resolved. It will be in the next release."
So according it , issue should be solved in the next release. Please , let me know it you can verify the solution (hope next month).
Thank you!
Thank Roland.
I see that 8.4.2 is scheduled for release on 11 April, so I'll check that the experience is working OK once I get the new version installed.
Cheers,
Allan
So 8.4.2 has been released and I've updated the View app on my HoloLens and the Studio software on my laptop. Very disappointingly, it looks like textures don't work at all on the HoloLens now
I tried a few different experiences and they all have this issue. I tried republishing them with the updated version of Studio - still no textures. I also created a new experience - still no textures.
And of course now that I've updated my app to 8.4.2, I can't go back to 8.4.1.
Hi @AllanThompson,
I am sorry for the inconvinience but this was statement form dev team that this should work now. I did send the model for testing and verifying. So will reopen the ticket.
Hi Allan,
now I did check the thicket and this was in the original report:
So I tested with Vuforia View 8.4.2 on HoloLens and it was working - no crash but without texture --- means texture is removed - is this what was your observations... sorry --- will wait now for feedback if no feedback until next few days will open a new issue.
One addtional quesiton- could you provide,please, a picture of an area of a model where we can expect the display of the texture?
I think , now in preview mode I was able to see the display dashboard / instuments panel- and navigation , radio panels etc.
Hi Roland,
I've got a simple experience that I've used in the past to test if textures are working on the HoloLens.
Here's what I see in the preview in Studio:
And here's what I see looking at the published experience:
You can just make out some of the details in the screenshot. The base model colour is black, so it doesn't come through really great.
Here's the QR code for the project:
Any model that I use that has any textures in it can be used and the textures won't display on the HoloLens.
Back in 2017 textures weren't supported, but that did get fixed at some point as I posted in this thread.
Hi Allan,
I reported now general texture display issue for the 8.4.2 as new issue / the first issue was for the 8.4.1 - vuforia view crash for model with texture. Reported to internal R&D community.. I will wait 2-3 days and if there is no answer will log direct R&D ticket.
BR
Thanks Roland
Reported the issue to PTC R&D ( no texture display on the HoloLens 8.4.2) - Ticket DT-22047
News ? 😞
The earliest that we'll see a fix is when 8.4.3 comes out which according to the PTC Product Calendar is due on 9 May.
I also have the same problem with the version 8.4.2 , since I upgraded the textures are no longer visible. with the previous version they worked very well. 😞
THE PROBLEM IS THAT CUSTOMERS WILL NOW DISPLAY EXPERIENCES WITHOUT TEXTURES. THERE IS A WAY FOR A DOWNGRADE.
