HoloLens problems with Textures in 8.4.1
- March 18, 2019
- 3 replies
- 8731 views
Hi All,
I encountered a problem with the latest version of the View app on HoloLens after the update to 8.4.1 came late last week.
I had an experience created that used a textured model created from an FBX file. The experience was working fine on the HoloLens using View 8.4.0, but after the update to 8.4.1, the view app crashes out when loading up the model
. I had to create a new version of the experience that doesn't have any textures and that loads up fine.
This happened on 3 different HoloLens's all running the latest version of Windows and 2 of them have been recently reset with nothing on them apart from the View app.
It's not a memory issue as the performance graph from the device portal shows. You can see the the loading, and then the plateau when the app crashes and the drop when it exits out of view which is still way below the memory limit:
It's not a global problem, as I have other experiences with textures that load up OK. Attached are the QR codes for the two versions of the experience - with and without textures. Unfortunately, I can't go back to the older version of the View app to try again.
Many thanks,
Allan
