How to create breadcrumbs (contained views path)
  • July 13, 2023
  • 2 replies
  • 1973 views
Hello PTC Community!
Please advise a solution for creating breadcrumbs that have links to different level views.
Example: Home../View1..../View2...../View3
Thank you!
Best answer by sgreywilson
You could provide published Experience URL using the url widget.
place you widgets as breadcrumbs and set the url to each published experience. When a user clicks on the link they will be taken to the experience inside the view app.
Assuming I understand the question correctly
Hi @IB_10645210 ,
no sure what is exactly required here. Where should be the bread.
So what I suspect ->You have a picture and on mobile you want to scann it and to click on it (or something like ) then you want to be able to click the different " Bread crumbs" to open specific experience , right? Or you mean different pictures which you need to select.
Important is to clarify
  1. How you want to do the selection.
  2. On which device and
  3. what should be the action what should  be used for the selection.
Could you, please, clarify ! Thanks
Hi @RolandRaytchev Roland, Thank you for response.
Sorry for the confusion. The "breadcrumbs" is a UI element:https://www.nngroup.com/articles/breadcrumbs/
I want to link multiple views from different projects in a "breadcrumb" on top of each 2D view.
Please advise any solution:)
@sgreywilson Thank you so much!
