How to give sequential effects when creating sequences?
Hello
When you create a sequence from an illustration, the content recorded in the step occurs at the same time.
I want to create a flash effect, then move the model and fade out.
However, the above three effects occur simultaneously.
In order to generate them sequentially, you need to divide or animate the steps for each effect.
However, animations do not work in ThingWorx Studio.
Also, when you step through each effect, ThingWorx Studio does not look good at showing you step-by-step through the buttons.
In other words, I hope that in the sequence phase, the effects or movements of the model do not happen at the same time but happen sequentially.
Any other good suggestions?
regards
