I want to Download Experience from cloud to my PC
  • February 22, 2021
  • 1030 views
Hello
I have do my hololens2 Project For my industrial IoT Sample
I do the good one PoC Project. deploy it to cloud and it still there!!
But
There is accident while I do editing project.
Project save file is collapsed and cannot open on Vuforia studio Portal
I want to download back the project that already deploy on cloud
There is some way to access it ?
Or else i have to re-do this all...........
Hello @Paitoon ,
so far PTC provide some rest API command where we upload/ publish a project or send metadata information e.g. with Curl command, but so far, I know, there is no option to download the project e.g. to zip file. Today I checked PTC database, but I could not find such option.
I think following option are possible  in your case:
1.) try to recreate the project for the old corrupted file
e.g. you can create a new HoloLens project and then from the old project try to replace the e.g. Home.js and Home.json (…Documents\VuforiaStudio\Projects\<yourProject>\src\phone\components )file into the new project (respectively viewName.js and ViewName.json) also all data from the download directory should be copied to the Upload folder (…Documents\VuforiaStudio\Projects\<yourProject>\src\phone\resources\Uploaded)
2.)open a PTC Technical Support  case asking the cloud team to copy your project from the  Experience Server directory on the Cloud instance and send it back to you
Paitoon1-VisitorAuthor
Hi
I selected to re-do my project now.
Thank you
