Is it possible to control an external data in JS?
  • March 7, 2017
  • 2997 views
Hi
When I call a service on some Things (external data), I drag and drop the button widget onto a service.
I would like to call a service by writing js code.
Is it possible?
Hi Yoo hwan​ Could you please share your use case in more detail.
yhwan1-VisitorAuthor
Hi
In my project, I can control the widget's visibility by writing js code and calling it.
Like this.
When I press a toggle button, playAll function is executed.
So, I want to execute a service in external data in the same way as above.
Not drag-and-drop but calling a function in JS.
Can I do it?
Hi, giri
Thanks to reply.
I tried it, but I didn't see any changes.
'query' returns info table data and the data is used in drawing a chart.
Is it wrong syntax?
