Issues with RealWear HMT-1 Help Bubbles
  • January 7, 2022
  • 1132 views
In RealWear HMT-1 Experiences there seems to be a problem with the $interval function.
When this function is used all the bubbles in the experience are blinking. Even tho some of them should be invisible (in a popup). While this occurs the RealWear doesnt recognise the right bubbles so the user cant interact with the bubbles.
setInterval should solve this problem according to PTCs R&D.
Hope this helps.
Best answer by VladimirN
Please send your issue here: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
VladimirN24-Ruby IIIAnswer
